Nice crank for MkII engine.
Photo's to follow - £75 - collection North Dorset - Yeovil area
Z1000 MkII CRANK
Z1000 MkII CRANK
Re: Z1000 MkII CRANK
Am I right in saying MK2 crank has 16 teeth for the camchain? But are the small ends 17mm for gudgeon pin? I think these are the best / strongest cranks for drag racing, interested Pigford, just got to see what a set of 32 teeth cam wheels are and a 124 link camchain cost. Thanks. Buzzard@thebuzzworkz.
Every man should have a shed (for bikes obviously..)
buzzard wrote:Am I right in saying MK2 crank has 16 teeth for the camchain? But are the small ends 17mm for gudgeon pin? I think these are the best / strongest cranks for drag racing.
Yes! Correct but also need to remember that they have a larger dia alt taper too so not a straight swap to the earlier motor without using the later alt and cover to match.
Thanks for the info Rob, I didn't know about the generator taper, it's never quite that simple. Still learning things. Buzzard@thebuzzworkz
sent you a whats app message
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
